Re: Creating Panels in CAD
September 14th, 2016, 11:50 pm
KenoLeon
like a quick sketch in a new medium it's not perfect, but here's a script I cobbled that I think almost does what you want ( you still have to press enter once per curve and it exports AI files) you can use it as a base for yours...
Sauce:
Code: Select all
# The Monet script by Keno Leon
# Notes:
# Exports profile curves from polysurfaces
# Substitute your DirectoryPath
# hide or delete curves, leave only polysurfaces
# Select profile view
# RUN script
# Press enter a bunch
# has a minor bug on export
# provided as is no guarantees Tested on Rhino for Mac v 5.2.2 OS X El Capitan
import rhinoscriptsyntax as rs
meshes = rs.AllObjects()
for solid in (meshes):
        rs.SelectObject(solid)
        rs.Command("_MeshOutline _EnterEnd" )
rs.UnselectAllObjects()
polys = rs.ObjectsByType(16, True)
rs.Command("_Hide")
curves = rs.ObjectsByType(4, False)
for index, curve in enumerate(curves):
    print index, curve
    rs.SelectObject(curve)
    DirectoryPath = '/Users/theMonet/Desktop/Dev/RhinoPython/'
    fileName = DirectoryPath + str(index) + '.AI'
    cmd = "-_Export " + fileName + " _EnterEnd"
    rs.Command(cmd )
    rs.UnselectObject(curve)
Best,
Keno
Eugenio (Keno) Leon
k3no.com Linkedin Instagram
September 20th, 2016, 11:13 am
NiMaTh
step one
step one
KenoLeon wrote:Not sure I follow.
Why not :
1) make a bunch of equally spaced panels
2) make a surface
3) boolean the surface from the panels
2 minutes work...
this....
super easy in solidworks (intersect tool)
if you set it up as structural members, you can verify if there are any duplicates.... allows BOM management to be simplified.
September 22nd, 2016, 5:09 pm
Zachary_Fitean
themonet wrote:
Zachary_Fitean wrote:http://www.123dapp.com/make
123D make by autodesk. Just make a form in rhino and import, 123d make does the rest and even lays it flat out for you
WOW! I've been looking for a tool like that for a while. definitely going to give that a shot.
Glad I could help!
Reply
