Earthman
The rule of thumb in the my old machine tool tech textbook is that casting patterns should add an extra 0.125" on precision mating surfaces. Then machined to tolerances with a secondary operation like thread cutting and facing. Metal casting like injection molding uses a sprue and gate system for mold flow but can accommodate a much greater variation in wall thickness. Ceramic shell investment process requires no draft angles as the part is broken out of the ceramic as a one-off waste mold.
Coroflot: 76078
Thanks! That must be 0.0125" extra instead of 0.125" I assume. If threads always have to be machined after casting this is going to be a bit above budget. I hear some factories can work with close tolerances up to about +/-0.010 in/in.
http://www.id-z.one
