Max_Caleb_Moody
Are there existing examples of good Design using rotomold, or is it doomed to be bulbous and flamboyant by its nature?
Coroflot: 67242
35:Chill designed by frog design back in the day. Radii are pretty tight.
Magis spun chair by Thomas Heatherwick:
Magis-Spun-Rotating-Chair-Thomas-Heatherwick-Image-courtesy-Chatsworth-House-Trust.gif
and a few others. While the radii have to be fairly large because you are spinning molten plastic in an enclosed female mold, when you consider the scale of a chair, they still look pretty tight. You just have to make sure you place your parting lines in a way that is aesthetically pleasing and in way that facilitates popping them out of the mold.
KenoLeon
Who are you calling flamboyant :)
I love the bubble club precisely cause it's rotomolded (you can probably cross a lake on it) :
Eugenio (Keno) Leon
k3no.com Linkedin Instagram
iab
Every single thing from the Mold-A-Rama at the zoo.
FH13
I guess we would have to have your definition of "good design".
A couple of products come to mind. Perfect use of the manufacturing process and end use. Well designed as well.
Gunner Dog Kennels
SKB Cases
SKB cases are good in that they also incorporate other processes to make a superior product with the right features.
Max_Caleb_Moody
Dan Lewis
iab wrote:Every single thing from the Mold-A-Rama at the zoo.
Sorry, what's rotationally molded here?
iab
My bad. I mistaked blow molding with roto molding. Us old folks tend to be forgetful, especially with nostalgia.
jacob fleisher
Mold-a-rama is injection molding.
NC30
Dan Lewis
jacob fleisher wrote:Mold-a-rama is injection molding.
Gas assisted injection molding. A hybrid of injection molding and blow molding. Interesting explanation here:
https://ashermade.com/2010/09/12/diy-mo ... w-it-works
BryanBrutherford
Actually, it's evacuation molding.
First, they pump a bunch of hot polyethylene that's been compounded with excess paraffin in to the mold cavity, next they "rapidly" cool the tool to build up a hard shell, then they puncture the shell and pressurize it with air while leaving an opening for the molten core to be forced out.
I'd say it's like a combination of injection and blow molding but absolutely not Injection Blow Molding, because that is a whole other thing.
It's probably closest to slush casting or slip molding.
This little beauty however, was roto molded.
Ryan Rutherford
www.brutherford.com
BryanBrutherford
oh man... you beat me to it... by minutes
I took too long typing because i was being a show off :D
Ryan Rutherford
www.brutherford.com
jacob fleisher
Nice clarification, gents. Value of the Boards as usual!
NC30
slippyfish
Coroflot: 2572
Opportunity to blow my own horn (eww gross)
You can get hard edges and semi-sharp corners in rotomolding. One of the issues to design for is the nature of 'poly-warpalene' isn't going to stay where you want it, unless some rib geometry is included. Roto is most often used for big/dumb/tough products because of the low cost of tooling and nearly indestructible nature of the material. You can do operations like undercuts though if you calculate the shrinkage rate; the ribs on these coolers are undercuts but shrink-out of the tool. Made with pride in the USA by IRP. You see these on the sidelines of NFL and some NCAA football games. Think 'Yeti' but sharper lines and cost-no-object features.
I've never seen small rotomolded products - as in smaller than a shoebox - but there's no real reason why small roto products can't be done, its just that there are better ways to do small things like injection blow molding.
“Traveling through hyperspace isn't like dusting crops, boy."
http://www.superformer.com
http://www.coroflot.com/skhid
ralphzoontjens
Coroflot: 76078
The Bubble Club chair by Starck is a great example of rotomoulding - it's comfortable too because it's hollow. Smallest radii I've seen were about 3mm and you can incorporate several technical features. The disadvantage is that the PE material scratches quickly, unless a new material has been developed that works with rotomolding that remains a disadvantage.
On that note, I am developing several bottles and am looking for examples that show the limits of the technique in terms of small deep sections, undercuts, patterns etc.
http://www.id-z.one
Reply
