I hate the basic dimensioning in Rhino. It seems like there is not much control over where dimensional units can be orientated on a dimension line without exploding the dimension and manually moving it around, which tends to look a little sloppy.
Does anyone know of a plugin for Rhino 4 that focuses on dimensioning? I used to export as a dwg and use AutoCAD but I no longer can use the software after switching to a 64bit system (PC).
If there isnt a plug-in…what do you use to dimension your drawings?
