Rhino popup menu export?
June 10th, 2009, 9:23 am
molested_cow
Can I export my popup menu that I have customized and load it on another computer? If not I will have to make it all over again.
I can't seem to find the info online and Rhino site too.
It's not the cows' fault, stop molesting them!!!
Rhino Popup Menu Export
June 10th, 2009, 1:41 pm
el dude arino
Go to - Tools / Toolbar Layout in Rhino
File / Save as - your current toolbar to a flash etc.
Then - Tools / Toolbar / File / Open your saved toolbar using the same method above.
Taking out flash drive and inserting it into other computer is implied.
Hope this helps, just tried it - worked for me.
June 10th, 2009, 3:32 pm
molested_cow
I did that, but it did not transfer the popup menu, you know, the one that appears when you click the middle mouse button.
i also tried exporting the "options" profile. Did not work either.
Rhino Popup
June 10th, 2009, 3:47 pm
el dude arino
Check this on the other console:
If that doesn't work, contact support in Seattle. They're awesome.
June 11th, 2009, 8:37 am
molested_cow
Ah got it. I have to close the default tool layout first to get that. Thanks!
