Reply
VPs of 2 cubes at different angles?
September 5th, 2011, 3:43 pm
Playdo
How do you draw 2 cubes that are at different angles, in 2 point perspective?
If the 2nd cube is rotated, both its VPs will change. The 1st VP can be set anywhere, but how do you work out its 2nd VP so that it gives the correct perspective?
Thanks
Re: VPs of 2 cubes at different angles?
September 19th, 2011, 10:52 pm
thedinomeister
Google searched "sketching rotated cubes" and found this from Pratt's ID Sketching course website:
http://mysite.pratt.edu/~jwenner/drawing_1.htm
Last edited by thedinomeister on September 19th, 2011, 11:22 pm, edited 1 time in total.
September 19th, 2011, 11:19 pm
Coroflot: 67242
That is one badass explanation!
Playdo
Thanks for that Dino. I hadn't come across it before.
Also, if anyone knows of a quicker method that doesn't require drawing a 'base reference' cube first, I'd love to hear.
Lmo
Indeed it is.... it always seems to come down to ellipses. Where was that explanation in 1969.. .. when I needed it?
Lew Morris
NURB
Playdo wrote:Thanks for that Dino. I hadn't come across it before.
That should come with practice. Drawing the reference enough you'll start to see it without needing to draw it. It's always good to have some references though, just to keep things in check.
Chris Haar
twitter:@chrishaar
Reply
