Reply
Motor cycle project
March 14th, 2016, 2:13 pm
cwatkinson
(put this in the wrong section) A project that i have long desired to do. Take a bike and get it restored, it runs but needs some part replacements and some rebuild
And now with two sons it will be a great opportunity to see if they like wrenching, not sure if its anything special 1974 Kawasaki 100cc but hey for $100 - with 10,000 miles i dont think i could have passed it up. I hope to post picks as we progress.
Re: Motor cycle project
June 11th, 2016, 5:12 am
Timmy_Johnson
Looking forward to see the outcome on this restoration.
August 12th, 2016, 12:56 pm
Bulgarianmod_info
Is it still working or it is already in peaces? How is the process going?
August 12th, 2016, 3:41 pm
cwatkinson
I hit a issue which was time for the project, so it will get picked back up soon...... need to fix the gas flow as i cant keep it running. it either gets no gas..... or pours outs.
I have rebuilt the carburetor and had that double checked for errors..... I'll post some images and videos. I want it running before i tear it down.
August 12th, 2016, 5:14 pm
jacob fleisher
I love a good internal combustion engine head-scratcher, especially motorcycles. I'll take a crack:
Sounds like it could be a float issue:
_float is pierced and leaky, so it floats sometimes and other times not (doesn't float when it's full of gas, then drains over time and floats again for a little while until it fills up again)
_float height incorrectly set, sometimes starving the bowl (larger throttle openings), sometimes not
_float valve worn, so it seals sometimes and leaks othertimes (flooding/gas everywhere)
_contamination (usually rust) coming out of the gas tank, getting through your gas filter (you have one, right?), and mucking up the float valve so it works intermittently, sometimes flooding, sometimes not
If you've done all that, then let's think about what ELSE it could be.
NC30
August 3rd, 2017, 3:38 pm
jacob fleisher
Hey CWatkinson - ever get your gas flow issue solved? Would like to hear about it.
NC30
August 4th, 2017, 7:52 am
cwatkinson
jacob fleisher wrote:Hey CWatkinson - ever get your gas flow issue solved? Would like to hear about it.
My proper authentic carb replacement kit, and gasket should arrive next week. (no after market for me again) then it just becomes time availability as im trying to complete the bedroom project.........
August 4th, 2017, 12:36 pm
jacob fleisher
Hope that does the trick! Keep us updated as you can . . .
NC30
Reply
