Reply
Blake_Maurer
I have a project that we are looking to make with compression molded EVA for a housing. I have never done any work with EVA molding, and I would like to now what are the typical submittals to get samples made when working with a supplier? Thanks for your help!
-Blake
engelhjs
By "submittals" do you mean what kind of files do you hand off? If that's the case it depends how detailed your housing is. Generally tight Illustrator drawings will suffice, but if there are particularly complex surfaces and/or details you may need a 3d model. Something as simple as a headphone case, for example, can be sampled from Illustrator drawings. A complex shoe midsole may need a 3d model. It may also depend on the sampling capabilities of your vendor.
Jeff Engelhardt
Giro Sport Design
Santa Cruz, CA
Blake_Maurer
engelhjs wrote:By "submittals" do you mean what kind of files do you hand off? If that's the case it depends how detailed your housing is. Generally tight Illustrator drawings will suffice, but if there are particularly complex surfaces and/or details you may need a 3d model. Something as simple as a headphone case, for example, can be sampled from Illustrator drawings. A complex shoe midsole may need a 3d model. It may also depend on the sampling capabilities of your vendor.
That is exactly what I was referencing. Thank you for your help!
Reply
