DMLS service recommendations
October 6th, 2015, 9:48 am
iab
Looking for a direct metal laser sintering house. I would like to make some stainless bicycle lugs. Basically 2 38mm tubes with a 1.2mm wall conjoined.
I've done the random Google thing. How about a recommendation instead?
Re: DMLS service recommendations
October 6th, 2015, 12:22 pm
FH13
I did some quoting a while back. Crazy expensive. Is machining them out of the question?
October 6th, 2015, 12:34 pm
FH13
I got quotes from Quickparts and ProtoLabs (Fineline Additive Manufacturing). The bigger companies are acquiring the smaller guys + I have a feeling they might also be outsourcing some of their jobs to prototype houses in Asia as well.
Best bet is to get 3 quotes and talk to them about the material and finish since it will make a difference.
At the end we ended up getting the parts we needed machined in SS from a prototype house in China, but it would take about 2 weeks lead time.
October 6th, 2015, 12:56 pm
iab
I have an rfq from Star out of China. I've used them before. Fineline threw me a crazy high number then I tried a random place and they were 1/3 the price of Fineline. I'd like to stay away from random picks but this is a new process to me.
As for machining, I have gotten 3 no ways so far. Complicated 6-axis stuff with a think wall. I imagine making the fixtures to hold the stuff could be a problem.
I am also looking into a rapid investment cast. Print the parts out of wax, etc.
Here are some screen grabs of the models.
ImageLugs09 by iabisdb, on Flickr
ImageLugs11 by iabisdb, on Flickr
October 6th, 2015, 1:36 pm
FH13
Same here. I was very hesitant to use DMLS because of high cost, prices varied so much, and tight tolerances were a must... and all 3 bureaus had different orientation & finishing options.
We have used RP prototype in China.
http://www.rpprototype.com/
Emelda Cariaga - emelda@rpprototype.com
You can contact them and see what they say.
October 6th, 2015, 2:12 pm
KenoLeon
Just curious, would something like Shapeways steel not be up to your tolerances,price range...
http://www.shapeways.com/materials/steel?li=nav
Eugenio (Keno) Leon
k3no.com Linkedin Instagram
October 6th, 2015, 4:00 pm
Dan Lewis
Investment cast stainless will give you a better finish.
October 6th, 2015, 4:08 pm
iab
Shapeways "steel" is 40% bronze and melts at 1600F. Stainless anneals at 1900F and melts at 2800F.
While an interesting material, I need the strength of stainless.
October 6th, 2015, 4:09 pm
iab
Dan Lewis wrote:Investment cast stainless will give you a better finish.
Probably less sanding and polishing time with IC. But I'm time rich, cash poor. Easy math for me.
October 6th, 2015, 4:47 pm
Sain
Coroflot: 252560
You can prob can find someone with a Formlabs and casting resin to get you a quote. Will be cheaper than Shapeways. etc.
Ex. https://www.3dhubs.com/calgary/hubs/gary
October 7th, 2015, 8:27 am
Dan Lewis
I think direct investment casting from a wax RP will be less costly than DMLS.
October 7th, 2015, 11:12 am
iab
Dan Lewis wrote: I think direct investment casting from a wax RP will be less costly than DMLS.
I think you are right, but it is too early to call at this time. Not a lot of places like making a one-off, rapid IC or DMLS. I have a lot of rfqs out there but not a lot of replies.
I need to start to call with a follow-up. You get a better response.
October 7th, 2015, 11:13 am
iab
FH13 wrote: You can contact them and see what they say.
Can't hurt. Thanks for the lead!
June 24th, 2018, 4:36 pm
ralphzoontjens
Coroflot: 76078
With what process did you end up making these?
http://www.id-z.one
June 24th, 2018, 5:31 pm
Coroflot: 67242
Haven't used them for this yet, but Forecast3D has a couple of laser sintering machines.
https://www.forecast3d.com/
Reply
