Re: Open link in new tab
February 27th, 2012, 5:45 pm
Playdo
The middle button's good for me
February 27th, 2012, 6:00 pm
Playdo
@Cyberdemon: Ok, I just typed in 'Design Forum' into Google and these are the 1st sites that I got back:
http://www.designerstalk.com
http://www.graphicdesignforums.co.uk
http://www.productdesignforums.com
http://www.webdesignerforum.co.uk
http://www.designforums.co.uk
All of them open external links externally. What I mean by external links are shown throughout the posts (websites, external sites etc): http://www.designerstalk.com/forums/web ... seful.html
It's not a big deal, but it is a nicer way to do it, purely because after you view a link, you want to easily go back to the original discussion.
February 27th, 2012, 6:13 pm
rkuchinsky
Coroflot: 33013
http://uxdesign.smashingmagazine.com/20 ... w-windows/
Just because others are doing it wrong doesn't mean we should too.
The Directive Collective
February 27th, 2012, 6:17 pm
Playdo
"It is appropriate to enforce opening links in a new window in case:
- the link may interrupt an ongoing process"
Source: Richard's.
February 27th, 2012, 6:30 pm
rkuchinsky
Coroflot: 33013
That case scenario is for things like a popup during a checkout process to verify your visa. Browsing a forum
Is not an ongoing process by that logic every link online would be a new window since you are in an ongoing browsing process
Did you the the whole thing? It's pretty clear cut. Sorry, you are wrong.
February 27th, 2012, 6:48 pm
Playdo
But browsing a thread is an ongoing process. Someone links to something, you check it out, then want to return to the thread.
This method may be wrong in your eyes, but not in the large majority of forums, and for good reasons. Yes, I read the article. But it was obviously just one side of the arguement, and it was contradictory as I pointed out.
February 27th, 2012, 6:54 pm
rkuchinsky
Coroflot: 33013
conversation is over. The article was clear. Browsing a thread is no more an ongoing process than browsing the entire web.
Usability people agree. You don't.
February 27th, 2012, 7:00 pm
Playdo
If that's your etiquette, then yes, my conversation with you is happily over.
February 28th, 2012, 1:21 pm
will_hough
rkuchinsky wrote:Just because others are doing it wrong doesn't mean we should too.
- Will | Hire Me
February 28th, 2012, 3:51 pm
Playdo
will_hough wrote:Just because others are doing it wrong doesn't mean we should too.
Method 1: Reading a thread - Click on a link someone posted - The page redirects to that site - Browse numerous pages of the new site - Want to return to the original thread - Repeatedly click back button until reached.
Method 2: Reading a thread - Click on a link someone posted - The site opens up in a new tab - Browse numerous pages of new site - Want to return to original thread - Select the previous tab.
In addition to the benefit of simplicity and speed (especially with a slow internet connection), you are also able to switch between source and thread for reference.
I've used both methods, and the second is without a doubt the most useful in a forum situation. Which would also explain why it is the most commonly used (yes, even if some UI designer argues against it under non-specific circumstances).
I don't expect it to be changed, and I don't mind as it's easy enough to open a link in a new tab anyway. I'm just surprised, from a designer's point of view, with some of the opposition here. It seems to me that some of you are inexperienced or just stuck in your ways, because method 1 is not as practical; it's poorly designed for its purpose.
For interest's sake, a poll would be good. Can one be put on the thread?
February 28th, 2012, 3:59 pm
rkuchinsky
Coroflot: 33013
Dead horse, consider yourself beaten.
February 28th, 2012, 5:26 pm
bngi
Coroflot: 128663
Playdo wrote: I'm just surprised, from a designer's point of view, with some of the opposition here.?
You and me both.
When Jakob Nielsen wrote these commandments, tabs did not exist.
Björn Bengtsson
iddqdse
"the unicorns do not look realistic enough"
February 28th, 2012, 6:02 pm
jada
Method 3: command-click the link when you want to open the link in another tab.
Even though I have sort of learned to live with the way Core77's front page works, I consider it to break what I would call a convention for good web design and I still cmd-click the links every now and then, forgetting that the links are 'faulty', resulting in an extra tab opened with an error message as the browser tries to open the javascript too (btw. it could have been implemented using plain html instead of a javascript, then this wouldn't happen. I suspect the javascript is used to disable the option "open in new tab" if you right-click the link, bad practice in my book as it causes unexpected browser behaviour for the user).
There should at least be some kind of indications that lets the user know the link has unexpected behaviour.
What exactly is the ‘look of buttermilk’ and why should I want it?
Reply
