Reply
PHP error
January 29th, 2012, 6:39 pm
phoenixproto
step two
step two
Weird error when posting to the design events forum. I formatted the post in Notepad2 which strips out all extra data & just leaves the text & the same error message came up for both preview & submit.
Error Message -
Method Not Implemented
POST to /posting.php not supported.
What is even more odd.... is that I can post in this forum & not in the other forum.
Thanks!
L
I would post the file, but I guess .txt is not allowed as a attachment.
Pro-active design support | Tight tolerances | Complex designs | Highly aesthetic surfaces - 3 weeks or less.
Rapid injection molded plastic prototypes from Aluminum tooling
Re: PHP error
January 29th, 2012, 7:07 pm
phoenixproto
step two
step two
Basically this is a cut & paste error.
Re: PHP error
January 30th, 2012, 11:32 pm
will_hough
How many lines are you trying to paste?
- Will | Hire Me
Re: PHP error
January 31st, 2012, 12:49 am
phoenixproto
step two
step two
Hi Will,
I was only trying to paste 54 lines of plain text. I usually just use Notepad2 as a plain text editor because that is what I use to write clean code without the extra data other word processors will insert that can make your code corrupt.
I am a big cut & paste person because I like to think about an answer for a bit, so I will write out my thoughts, edit them, add markup and then post. I don't post much because usually by the time I am satisfied with an answer.... someone beat me to it & I don't want to be redundant. I know as a manufacturer my welcome is as good as my info and actual contributions to the community vs my posting to post and being annoying to the members.
I went back and typed out what I had to say & had no problems. So, that is why I reposted that it was a "cut and paste" error. I didn't want the admin's to drive themselves crazy chasing an isolated issue when I am sure they have bigger fires to take care of on this board.
Take care & thanks for looking into this! :D
L
Reply
