Wacom aspect ratio vs Screen Ratio
22" widescreen
6x8" tablet
Hence, if i draw a circle on a tablet using a template, its an elipse on screen. this must wack my drawing ability.
Way to fix?
Cheers guys.
t.baker.
Below if you are using and Intuos table… let me know if i is not, I have an old ArtZ one at home i can check for you.
start/control panel/ double click wacom tablet
click on the tab for mapping (left middle of screen)
There is a picture of the monitor and the tablet. set to Full and Full but check your “force proportions” and you are set… you should see how it works in the picture… the bottom inch of you tablet won’t be usable.
good luck
