As I wrote in the other thread, I made a second bike. The first one took about 10 years. Mainly due to the cost of printing stainless steel wasn’t cost prohibitive until about 5 years ago. I wanted to go “fast” for the second bike, it took about 10 months.
Since the cost of printing metal has come down, there are several companies, Sturdy/Firefly/etc., making printed titanium bikes. Some pretty cool stuff if you check out their sites. There is small steel printing at a production level, but it is minimal. Colnago made the Steelnovo. Cinelli now prints its XCR road bike. I’m cheap. Printing steel is about 25-33% the cost of tinting titanium. Also, I can weld steel, I have zero experience welding titanium. Yes, there is a weight penalty to steel, but maybe it is a half pound at most. My fat ass could stand to lose a half pound.
This time I went internal lugs. Saves a yuge amount of time to straight cut tubes over mitered cuts. It could be brazed, but I welded, just to do something different. I also very much love the minimal look of internally-routed brakes. Looks like a track bike. 1x to continue the minimalism and because there is no reason to have 2x any more with 12/13 in back. I went SRAM etap 12 for the wireless and the 13 is stupid expensive. And then some fun with anodized parts.
My apologies for some of the pics taken in full sun.
Test fitting with printed plastic. First with paper tubes, then Columbus tubes.
I used a Deda fork with a D-shaped steerer tube to allow the internal routing. But it still requires a 1 1/8 to 1 1/2 tapered head tube. Which can be OK with crabon but has a fat bottom with steel tubes. Still bugs me and on the third bike, I plane to fix that.
Finished bike. Last pic is me finishing the 60-mile Hungry Bear gravel race. It did not break, so I consider the design a success. And Gulf livery because, Gulf livery.
Holy catfish that’s cool as hell. Really like the caliper mount! What Columbus tube set, is it straight tubing or did you have to cut off a lot of butting.
A combination of Spirit and Life. I don’t understand the difference, But yes, all butted. The first bike is their premium butted stainless tubing, XCR.
Its the one thing I don’t do. I can design it, but I can’t put it down. Really not a shop per se. A guy who does have access to a booth at his main employer, a model shop. His side gig is bike mechanic who can paint bikes too. Its actually pretty awesome. Nothing wrong with powder, but nothing beats wet paint.
I’ve done a bit of brazing (slightly fancier pipe sweating) but I’m not sufficiently up on welding between parts like this… where is the bead, or how do you get weld penetration with such a long overlap and tight-ish fit? Are you doing a lot of grinding afterward?
Nice job hiding the seatpost clamp, I can’t figure out where it is. If I was making a full custom bike I might just extend the seat tube to approx my preferred length and to hell with resale value.
I’d really love to make a “last bike” light whippy hardtail.
TIG welded. You can weld mild steel to 316 using a 309 rod. Just a single bead around the circumference at the butt joint. Some grinding and bondo, but not bad. The overlap carries the load. The weak point is the non-drive chain stay joint. I’m still waiting for the paint to crack there. Hasn’t happened yet. knocks on wood.
You can see the grub screw in the bare metal seat cluster pic. Think Cinelli 1R wedge. Except this one is stainless steel and won’t crack in half like the aluminum ones Cinelli made. Again, saving a couplethree grams is stupid sometimes.
One other thing, if I were to have brazed, I would have printed a speed bump running the circumference at the butt joint. It is easier to feed brazing rod with the speed bump. Think Masi Volumetrica.
Shipping a full bike is a pita, especially from Firenze. Gonna be 200 euro plus 15% tariff. Get just the frame, build it up.
I’ll be at a swap in Milano in February, want me to look? I will also visit with Simone at the Masi shop at the Vigorelli (Alberto sold it to Simone back in 19-ish). I can ask if he has some old stock to sell.
Tolerance on these smaller parts is +/- 0.2mm. So on the walls that need to fit, I use the +0.2, turn it down to fit. Nominal wall thickness for a lug is 1.2mm. So at the walls that fit, mine are 1.4mm.
I find the tolerance on the tubing sets to have a much higher degree of variability. My recommendation is buy that first, measure twice, print once.
