SWX Blocks Motion
How can I simulate one object being moved because another object is pushing against it using Sketch Blocks in SWX.
Why are you trying to use blocks? Why don’t you just setup some those objects in an assembly using some mates and physical dynamics you should be able to simulate that pretty easily.
I believe you can set another line to connect b and c and apply a traction constraint to it.
Using blocks is really good to figure out mechanical movements before committing to geometry.
I can only get traction relation between a circular object and line won"t work on box shape.
