solidworks materials editor
I am new to Solidworks and am trying to create a custom material with the specs of what the company already uses. I can’t figure out how to add new physical properties to a material however. Any suggestions?
you need to create a new data base.
this’s from the SW help:
to create a new data base:
In a part document, click Edit Material on the Standard toolbar, or click Edit, Appearance, Material.
In the PropertyManager, under Materials, select a material, then click Create/Edit Material.
In the dialog box, on the General Information tab, under Database Selection, select .
In the Save As dialog box, type a name for the database file (default extension .sldmat), browse to a folder, then click Save.
You can specify the default location for Material Databases in Tools, Options, System Options, File Locations.
Click OK, then go to step 2 in the next procedure to add a custom material to the database.
to create a custom marterial
When you create a material, you derive the properties from a SolidWorks default material, then change the properties as necessary to create a different material.
In an open part, click Edit Material on the Standard toolbar, or click Edit, Appearance, Material.
In the PropertyManager, under Materials:
Click an item in Select a Material Database to specify the material library where you want to create a material.
Expand a material classification, then select a material.
Click Create/Edit Material.
Set the properties as necessary on the General Information, Visual Properties, Physical Properties, and Crosshatch tabs.
Click OK.
Click OK to close the PropertyManager.
to edit a custom material
You cannot edit SolidWorks default materials. You can, however, edit materials that you created.
Click a database you created in Select a Material Database to specify the material library that contains the material you want to edit.
Select a material that you created.
Set the properties as necessary on the General Information , Visual Properties , Physical Properties , and Crosshatch tabs.
Click OK.
to remove a material
In a part with a material applied to it, click Edit Material on the Standard toolbar, or click Edit, Appearance, Material.
In the PropertyManager, under Materials, click Remove Material.
Click OK .
The material is removed from the part and the material name is removed from the Material icon in the FeatureManager design tree
