Sketchbook Trial Issues
So, I downloaded the trial of 2010 Sketchbook pro cause I wanted to try the free rotate canvas tool. However, the tool does not appear when i start the program. Is the trial version just not feature it? I’d like to get the program, but if it doesn’t have the free rotate like painter then I’ll have to pass.
Thanks in advance.
Hello,
The rotate feature should work in the trial. Do you know how to use it? Hold spacebar and then hover over the “rotate” ring of the puck. Click and hold the ring to rotate the canvas. If it isn’t working, then I’m pretty sure it is disabled if your video card doesn’t support the feature as it relies on OpenGL to work. Does that help?
