Rhino Problem
I have been using Rhino for about four years now and I am very comfortable with the program. My problem is that every couple of months my toolbars will dissapear and I am unable to retrieve them. So I have to uninstall and reinstall the program to continue my work.
Has this ever happened to anyone else? What can I do to correct this problem?
Thanks in advance!
Goto Tools>Toolbar Layout>FIle>Open then browse for the .tb and .wb fils you need from the Rhino program folders. Flamingo toolbars are in the plug-ins folders.
I’ve never experienced the problem you describe. What version are you using?
You might want to inquire with McNeal & Assoc. to see if they are aware of the problem and/or have a patch or update available.
I believe this is a known bug. It will be on the Rhino NG… do a search.
:)ensen.
