Rhino on virtual pc
On the Rhino website it says that it will run on virtual pc, anyone tried this?
yeah, it works. I don’t know about on the new OSX. But I’m on mac 9 and run it through virtPC using windows 2000. Only potential problem I found is I think there’s a technique where you start in one window, hold a control key and switch to another window view and you can still reference stuff from the first window…something like that in my tutorial, it didn’t work on the virtual because the key you use is what virtpc uses to switch between it and the mac mode. Other than that one issue which you can easily work around, everything seemed fine.
