Where/how do you get those last models, the greenish colored ones in the process sheet, that get tracing paper glued on? Do companies/manufacturers typically supply those?
@slippyfish we custom built at a last manufacturer here in Portland it based on a few target shoes and then how the founders wanted the fit to feel. Then did simple pullovers to check the fit, made adjustments. These blue lasts are CNC’d from blanks and pretty expensive, but all a part of the development process when working on a new shoe like this. I can connect you with some folks if you need.
I think that is where developer Drew Linth and my experience comes in. From the get go I designed a pretty beefy rubber bumper the cups the toe box to keep you on the platform while cutting and also for toe drag. I designed this very flexible broken herringbone traction so it would give you multidirection traction but still move with the foot. They basically act like a bunch of little wiper blades. Had this been just a basketball court it would have been fine but once we tested it on outdoor tennis courts, those blades were blowing off. So we made some changes from the initial wear test samples to change the traction, inverting it and scaling it up in the heel and toe and adding material selectively in high wear areas, while being careful not to impede flex as much as possible.
This is from someone who wore them for 22 hours of hard play on outdoor courts.
Cool just curious. It’s neat how the feel and fit is engineered into the shape.( I guess that should be obvious.) How many lasts do you need to evaluate or just the size 10?
Yes, so much has to be engineered into the last (the foot shape). In this case it is a bit of a triangular foot form (narrow heel, wide toe box, almost a little squared off).
Then because it’s a zero drop shoe, the bottom is almost flat with very little toe spring. If you try to take a regular last that has 10mm heel to toe offset and make it only have 6mm of foam the entire way you end up with a shoe that has it’s toes pointing up in the air (the toe spring), so the last has to be flattened out. We worked with a last maker with a huge library of existing lasts that we could modify and back into the right shape to start testing.
Once we felt good about it we opened up soft tools in Men’s size 11 and Women’s size 7. then made more last and tooling adjustments to tool and test again. It’s a fun process if you lean into it.
Imagining a diagram like something from the H-point auto design book where engine placement dictates proportions, but for footwear to describe how a hoops shoe will need to look different from a tennis vs jogging vs sprinting vs skateboard etc. shoe.
Yo or RK likely posted an image like this years ago.
I think I did a video on this back in the pandemic and posted it to YouTube but can’t seem to scrounge it up. Closest I could find was this little sub page I had on my site back in 2010…
yeah that’s what I was remembering. I think H-Point does a great job with hammering-home the idea of ‘packaging’ versus styling, and what influences architecture. Would be a fun encyclopedic endeavor!
Ironically these have a similar construction. The Zoom Street Milers were also a cupsole with a drop in sock liner (that had full length zoom air in it). The Miler’s cupsole was much thicker though and focused more on streetwear obviously (hence durable) vs the Pines is more focused on weight/flexibility which is why I had to add a bit more material in those high wear areas to get it back in balance. I went too far initially trying to make it super light.
