Perforated aluminium mesh
Hello all,
Where can I find real fine mesh like the speakers grill or shaving foil?
the closest I get to is www.mcnichols.com.
Thanks for reading,
J
Check out MetaPerf at www.azahner.com
How much material are you looking for? How big does each piece need to be and do you have any specs on hole size/spacing?
hi alll
MV
thanks for the link.
USCN
I am looking for aluminium diameter 1.5mm pitch 2mm.
I am talking to some fabricators. very expensive stuffs you talking
about was told.
I dont have weblinks handy… and unfortunately these are all UK & Europe based concerns… some might have US distributors… or might be able to suggest somewhere
but try
NOVA Metals
GKD
Cadisch
HWBF
This company caters to the Casemod community, which means they supply small quants. of material. Nothing sucks more than having to buy a 6x6 foot sheet to get enough for a 1’ square speaker. It’s kind of big for your specs though.
http://www.mnpctech.com/moddersmesh.html
I’ve seen amazing results making your own mesh using the plastic netting frm grocery stores to make the casts… then again that was in a jewlery setting (made for an absolutely stunning gold/neodium broach if I remember correctly) so it may not do what you need…
I have a source that specializes in audio equipment. If you can tell me how much material you are looking for, I can ask them if they can supply it.
Sorry about the double post. I will also need to know how thick the mesh has to be. cheers.
USCN,
thanks for the effort.
i have managed to locate one that specialises in speaker mesh.
its USD0.50 for 7700 sheets of 3 x 2. 0.6mm thick. cheap!
Share it!
