Hey man.
I have been following KG for a while now. Finally, I am getting involved.
First, I think you have had a pretty good year. Very consistant, but I am sure you did not post to hear the praises, and although I am far from a “vet,” I think I am familiar enough with your work to hopefully add some helpful critiques.
I always knew I could expect a nice, clean design and rendering from you each month. Unfortunately, I think your renderings are missing a bit of a knockout punch. I think this has to do with the way in which you choose to render in illustrator. The designs are always, “dang” at first, but I somehow lose interest. I think this has to do with the lack of expressiveness in the rendering.
I think if you would combine what you do in illustrator with PS, you would be killing it. For example, do your sketch, do your linework, then take the linework into PS. One thing I have found helpful is dropping the linework into photoshop as PATHS. You can then make selections based on these paths in Photoshop and render from here.
To take this a bit further…I have done a quick 10 minute bump up in Photoshop to show you what I mean. I think you could take these paths into Photoshop, make sure they are closed so you can do your fills, then render the form as a whole. This will make the form read more and your renders will look less flat. Second, use the paths to make selections for each detail you wish to add. I have made a bit of a soft chamfer around the black (below). I just made a selection with the lasso tool for now, but if you had those paths, that selection would be perfect. You could then feather the selection to make it as soft as you want. This could add to the design’s aesthetic. Also, I think it would be percieved as more real if you made these surfaces have some depth rather than them just running up to each other.
I have included this image which I just did two layers over your existing render. One was a “cores” layer, the second is a “bevel” layer.
I think many of us would be happy to be where you are, but I thought it would be more helpful for you to be a bit critical.
Take care man,
David
