mixing powdered ceramic in clear plastic for silicon molding
hey,
does anyone have any experience mixing things into a plastic/resin for silicon molding. i have a rapid prototype of a coffee cup design that i am making a silicon mold off and was thinking of smashing up ceramic plates into a fine powder and mixing that with a clear plastic to give it an interesting look/ texture.
any thoughts??
any other ideas of things that could be mixed into a plastic, shredded paper, finely smashed glass, things like that??
thanks very much
Almost everything will settle to the bottom of the mold before the resin gels. Its a specific gravity thing – in order for the additive to float in the resin it needs to be very close to the specific gravity of the resin.
or, if you have the time, build a “simple” 3-axis roational fixture to keep the filler in suspension until the resin gels. Of course, the mold would require a plug to keep the resin from leaking out. Think plywood frame, brass tube bushings, 5-minute epoxy, battery powered motors, low r.p.m., etc.
How to insert the filler in a uniform manner (considering the wall thickness of the cup) might be a problem.
