Hypershot weird angle
I am using the older version of hypershot and whenever I render, it shows up with an awkward angle. Looks orthographic than perspective. Is there a settings that needs to be changed? Help please!
Settings > camera > uncheck orthographic? or adjust your field of view (FOV), focal length, or perspective values.
I think what you are doing is changing the focal length rather than changing the camera distance. Change the camera distance using ALT + RMB. Change the focal length using ALT + wheel.
I suspect you are trying to move the camera closer to the object, but you are actually changing the focal length to a very large value so it appears orthographic.
BTW, KeyShot is HyperShot. We offer free upgrades to KeyShot 1.9. And you certainly want to check out KeyShot 2 while you are at it. For more info, visit www.keyshot.com.
Thanks! it worked. I was using alt + scroll. and in ortho.
