HydroFlight to Firefighting: Rain-Cloud Aerial Monitor
The RainCloud Aerial Monitor marks the point where our sports hydroflight work crossed into firefighting. We took years of water‑thrust flight experience and asked how it could help real fires on waterfront structures that are hard to reach from land. An early idea of putting a firefighter on a flying platform with a hose made the risks clear, so the focus shifted to a remotely controlled aerial platform that could go into danger while the operator stayed back.
Concept and hardware
The concept uses a floating pump unit and a water tether that does double duty: it lifts, balances, and steers the platform, and it delivers suppression water to the fire. From there, the platform evolved toward a quad‑style arrangement influenced by multicopter thinking, with one stream directed forward for suppression and four used for steering, stabilization, and elevation. Control became a major part of the concept, expanding from simple engine control toward balancing multiple jets, radio transmission, and software logic for vertical motion, forward motion, side slip, rotation, and aiming under load.
Simulation and operator interface
The Unreal simulation video is built for behavior, not visuals. It shows the unit launching from the water and moving around rigs, ships, and shoreline tank fields while a user controls the stream, thrust, height, and position in real time. We use that environment to shape the operator’s interface, test scenarios, and make big hardware decisions before committing to production hardware and physical prototypes.
To develop the concept, we used Rhino models and Unreal simulations to work through geometry, water routing, basic platform weight, structural needs, and space for electronics and control systems. Those studies also made the limits of the early version clear: some shoreline tanks, ships, and offshore structures sat within the operating envelope, while others demanded more height or more delivered water than this first configuration could provide. That is why we saw the RainCloud Aerial Monitor as an early version rather than a finished answer, and why later work moved in the broad direction of more height, more power, and more water.
Operator experience
The operator experience is built around having a front‑row view from the firefighting platform while remaining at a safe distance. Instead of standing on a water‑thrust board in heavy gear near toxic gases and structural risk, the operator stands off and flies an unmanned platform that carries the nozzle. The camera and control interfaces are set up so the operator sees along the firefighting stream toward the target, as if looking from the platform itself, without being physically exposed to the fireground.
In practice, that means the user can watch the unit approach from the water side, adjust height and angle to match the structure, and then shape the stream and thrust to hold position while delivering water. Additional drones can provide complementary viewpoints, drone “wingmen” that give overhead or side perspectives, so remote observers can coordinate suppression with more situational awareness than a single ground‑level view would allow. The Unreal simulation is part of this operator story: it lets users practice manipulating the craft, balancing thrust and stream, and managing position around rigs, ships, and shoreline tanks in real time.
Context and intent
In the current landscape, waterfront energy and tank farm infrastructure, including sites in the Middle East, face a mix of conventional fire risks and newer forms of disruption and damage. In those environments, being able to put an unmanned platform over the water, deliver high volumes of water from height, and give remote operators a front‑row view from the firefighting platform at a safe distance matters not only for accident scenarios but also for situations where direct human access to the site is constrained or more exposed than it should be.
This release is intended as a defensive publication: a public record (into the Core77 timeline “blockchain”) of an early configuration and its simulation context, while later and more proprietary development remains outside the scope of what is shown here. The RainCloud Aerial Monitor itself grew out of more than twenty physical hardware iterations, and AI‑assisted simulations in Unreal and Rhino/Grasshopper have since added dozens more configurations beyond what this early version documents.
Where this is heading
We see this as the beginning of a much larger direction. There is active work underway to push height, water volume, control capabilities, and hardening further, and we plan to keep developing the concept into more robust and more specialized firefighting systems over time.
Very cool! It’s nice to see that technology used more.
