how to SILKSCREEN
I am a graphic designer and would like to learn how to silkscreen. I silkscreened in high school art class, so I have a general idea of how it works. I think I will start off with t-shirts or posters in my basement - I’m not thinking “home buisness”.
I started with a google search - that led mostly to a definition of the process and a lot of information on starting a home business. And amazon book searches pulled a lot of books written 30-40 yrs ago.
I’m hoping someone can direct me to a book or website that offers up-to-date, in-depth information on how the process works and materials I will need.
thanks.
Screen printing can a pretty hefty job to take on at home. You need to find an ink that will cure without heat, which I do not know of otherwise i would be doing it at home. As far as shirts go, you have to cure the ink on with heat, otherwise if you use regular ink it will wash out. I will ask a professor of mine to see what books might help. But if you have specific questions, please do ask i studied screenprinting as an undergrad.
there are quite a few must haves for screen printing, so i am just wondering how deep you want to get into it, how much money you have for it, and how detailed you need it to be.
I just want to get a general idea and start with the simpliest thing …
then test out the more complicated.
i don’t have any specific projects in mind. I just want to experiment.
thanks.
http://www.nazdar.com/
here is kinda a DIY site
http://www.kcdirectaction.net/ARC/fun/screening_instructions.htm
check these sites out … they have a lot of supplies that is needed.
here is my list for you to start small with
-frame
-silk screen fabric
-squeegie
-screen stop (which allows you to mask the parts that you do not want to print)
-screen cleaner (which cleans off the screen stop)
-and some kind of table set up that will hold your screen and allow you to lower it onto the surface you want to print on
-You also have to understand that you want to have a suction system or a tacky surface that will hold the paper/t-shirt down otherwise it will stick to the screen once you push the ink through.
hopefully the site helps …
i will keep looking
A friend of mine had a simple home silkscreening kit that he picked up at Hobby Lobby or somewhere. He made some cool shirts with it, no heat cured ink either. He printed a black and white pattern onto overhead transparency film and used that as a mask for the screen (cured with a regular light bulb). It worked great. Sounds like what you need, if I find it I’ll post again.
I played around with something like this:
http://www.shoptheartstore.com/product_detail_single.cfm?productID=13E7DB81-18F3-4532-8D57E1EE3355B5D0&shownav=0
and had decent success. If you get some clear acetate, you can print your designs on a laser/inkjet and use computer generated art.
This is the page for screening.
I totally rely on this website for fabric/surface design supplies for dyeing and making stuff- it also sells super-cheap clothes that can sometimes be fashionable that you can dye or print or whatever!
Hope this helps!
i just purchased this dvd the other day, so far its been great
http://www.fredflare.com/customer/product.php?productid=257&cat=329
