HElp with RHINO command
HEllo,
My daughter is using Rhino 3.0 in school and is having trouble with getting the words on a label to wrap around a cylinder properly. She is doing a bottle and the basic commands she uses either distort the letters or they stick off of the sides in stead of wrap around. Any ideas?
Thanks, Kim
Create the text → Use Curves-Curve from Objects-Pullback (alternately type _pull in the command line) → Select target surface → Voila![/b]
Thank you so much!! I will let her know!! :smiley:
Use the flow along surface command (FlowAlongSrf). Type it in the help to see how it works.
