Footwear survey
Hello,
I am researching footwear in the context of fulfilling users’ diverse daily needs. If you can spare the time to share your options, and experiences on footwear; I would appreciate it. Also, if you would like to post some constructive criticism on the survey here on this post please do.
http://www.surveymethods.com/EndUser.aspx?C3E78B94C1809490
Pasting into address bar may be the most effective method.
Thank you for your input.
Filled out the survey :slight_smile: Im curious though are you just using this for research or is there an ID project associated with it?
Done.
Some of your questions need a Not Applicable response instead of forcing an answer. Other than that, nicely done.
