I need to get a bright matte, as close to “white” effect from a piece of 302 stainless steel. I can either surface treat the steel to look brighter like some satin aluminum or simply paint it white.
My question is is it cheaper to do a surface treatment to teh metal or paint it?
My other question is is painting on metal considered “eco-friendly?” or “recyclable?”
What’s the application? There are some Ultra Low VOC polyurethane paints out there that you could tag as eco-friendly.
I’d guess that any surface treatment to make stainless steel white would involve chemical etching and a number of other methods, all of which would likely be eco-UN-friendly.
although powdercoating stainless is a bit pointless
just curious… why are we using 302 (instead of CRS)? Is it the primary material used in the shop? Some other mechanical issue requires it, i.e. a marine application?
