alsa chrome paint
…anyone tried this stuff?..how did it work out for you?..
discussion thread on Alsa and Fantachrome;
http://www.pfonline.com/dp/forums/forum_results.cfm?t_id=1880&pub=PF&f_id=19&m_id=4581#4581
I’ve used the Ghost Chrome paint and really like it. It is expensive, but worth it. I found if you spray it a little on the dry side it works best. You want to be sure the paint flashes between coats. The color possibilities are endless. You paint a base color first and then the chrome on top. Depending how thick you go with the chrome you’ll get different effects.
