Alias Studio Tools 13 Shortcuts?
Hey, I’m learning how to design using Alias Studiotools for a project at uni.
I have been searching like mad for a list of Alias Studiotools hotkeys or shortcuts all on a page like a reference style layout.
For example like this one for photoshop http://user.fundy.net/morris/downloads/PSCS2_Shortcuts.pdf
If anyone can point me in the right direction it will be greatly appreciated!
sorry, nothing in the help files i could find now. but your specific hot keys are located at
“C:\Documents and Settings<your-login-name>\Application Data\Alias\StudioTools\UserPrefs12.0”
in the “_AliasHotKeys.scm” file. open it with a text editor such as notepad. it looks bad but you can shortly reduce it to the relevant info with judicious use of find/replace.
this assumes, of course, that you’re using windows and that your documents and settings folder is on the c drive, and that your version of alias keeps the config files the same way as mine, a not unreasonable assumption.
if you are locked out due to some university policy then repost and i can post a short list of shortcuts on this thread.
go to
Preferences>Interface>Hotkeys
you can assign your own hotkeys to pretty much eerything. I’ve found the default Alias ones to be pretty arbitrary…
The default list can be found via Help > Modifier Keys.
