2 part plastics?
Hi guys, i am need of some 2 part mix yourself plastic recommendations, I need to cast some parts to make a prototype and i would like a recommendation for a semi-flexiable, similar in properties to pp or pet in terms of strength. Ideally i want something which i can mix and mould at home for a prototype.
Cheers!
First, do a search on this forum for urethane, casting, mold making, etc.
Then check out: Casting Thin-Walled Parts
Then look through;
Cut to Size, Polycarbonate & Acrylic Plastics : TAP Plastics?
http://www.freemansupply.com/LiquidToolingMater.htm
http://www.thomasnet.com/prodsearch.html?cov=NA&which=prod&what=urethane+casting+supplies&navsec=search
If flexablility is really necesarry for your parts i’m not sure which way to go, but i use por-a-cast or tap plastic’s quick cast a bunch and they both work great - standard 2 part urethane casting resins with about 5-10 minute cure time.
Por-a-Kast : 小仙女av资源导航,成年av网站18禁,白丝袜jk被捆绑憋尿出来,呆呆女神肉足丝交到吐
