What laptop to buy?
Postby seung73737 » August 26th, 2015, 1:12 am
seung73737
Hello, I'm an Industrial Design student in my fourth year and I'm searching for a new laptop because the one I have now is not handling the software too well. It's a Samsung NP-QX411 and I've used it for 4 years.
I'm planning on using Adobe suite ( Photoshop, Illustrator, In Design, After Effects, Premier Pr0), Solidworks, Keyshot Pro, Autodesk 3Ds Max and Fusion 360 but my laptop now cannot handle Adobe Suite + Fusion 360 and it's slowing down my work progress significantly.
I'm looking into Lenovo products and Macbooks.
Any suggestion would really help me.
Thanks! :D
Re: What laptop to buy?
Postby Paul_Kalousek » August 30th, 2015, 10:06 pm
Paul_Kalousek
Disregarding the whole topic of mac or pc, Ive used a Lenovo y510p through 2 years of education and a year of professional work.
Not sure if they still make this model. The platform supports dual graphics and you can easily expand ram and memory as you grow with it.
IBuyPower also worth looking into
Sent from my iPhone using Tapatalk
Postby sonofscrotum » August 31st, 2015, 6:45 pm
sonofscrotum
If you are planning to run SolidWorks it's recommended you have a workstation with a Quadro or FireGL graphics processor.
Postby fugenxsaudi » March 4th, 2016, 6:50 am
fugenxsaudi
From my choice i choose MacBook with Quadro processor.
Postby design-engine » March 4th, 2016, 8:09 am
design-engine
Go Dell referb Choose from the Video cards suggested above + get Dell precision laptop machine. Search their site then call in. The sales rep can see all the new product that has not gone online yet. + get the 2 year warranty. We use all Dell at Designengine and have for 20 years.
Bart Brejcha
DESIGN-ENGINE|EDUCATION
http://design-engine.com/category/courses/ SolidWorks surfacing classes
Postby Generatewhatsnext » March 4th, 2016, 9:09 am
Generatewhatsnext
If you're an ID student you'll want to be sketching a lot - and digitally. Go with a Surface Pro 4 unless CAD is paramount, then maybe a Surface Book with the Nvidia GPU. Microsoft has student discounts available in their stores and online.
Scott Snider
Partner, Product Development
Generator, inc.
skype: generatewhatsnext
Postby design-engine » March 4th, 2016, 11:12 am
design-engine
We use Wacom tablets at designengine. Does that Surface Pro work the same? If so defiantly Surface Pro 4
Bart Brejcha
Postby estardabill » September 3rd, 2016, 11:43 am
estardabill
buy any laptop but don't buy laptop with graphic card.
Postby ralphzoontjens » September 7th, 2016, 2:42 am
ralphzoontjens
The Surface book from what I see will be a great machine for an ID student.
If you're more on a budget consider the Toshiba Satellite Radius 15 P50W-C-10V.
Go for at least 8Gb RAM and a 256 SSD. Intel HD Graphics works fine, in fact I disabled my AMD card because the Intel card is more reliable particularly with Solidworks.
I always prefer to go for more performance and have a separate Wacom, it works for me as digital sketching is only a very small portion of the work that I do.
I have a Toshiba Satellite P50-B-10L for two years now and it is still a spectacular machine with 8 i7 processors, 16Gb RAM and a 256 SSD.
http://www.designsoul.nl
Postby lipsrose » September 20th, 2016, 4:07 am
lipsrose
I think Dell or Samsung brand is enough for common use.
Macbook monitor is great for designers to work with PTS or Illustrator, After Effect.
Postby MK19 » November 18th, 2016, 6:48 am
MK19
step two
step two
Never buy HP. I say that as someone who has everything HP. Build quality is junk, they're just cheap. But the cheapness has drawbacks. No proper heat dissipation on laptops for example.
What you want is an i7 6700 HQ, 16GB RAM, and an Nvidia 960/970/980. Ideally you want also an M2 SSD for your OS and an additional 2.5" SATA slot for a HDD so you can pick up a 1/2/3/4TB drive to stick in there depending on your needs.
For brands I would advise Lenovo or Asus and really nothing else.
For size I personally think the benefits of having 17.3" over 15.6" are massive. That 1.7" difference just makes the working experience so much mor enjoyable. There is also the added benefit of increased productivity through a larger screen size. The drawback is size/weight for carrying it around.
Postby cadjunkie » November 21st, 2016, 9:06 am
cadjunkie
Highly recommend the Lenovo P50. You get a Quadro video card, up to 32gigs of RAM and a 2TB SSD is about $500. (buy the RAM and SSD separately). Spend as much as you can on the processor at least an i7 but the xeon can't hurt either.
This will cover just about all of your needs for at least 3-5 years.
Postby Cyberdemon » November 21st, 2016, 1:14 pm
Cyberdemon
MK19 wrote:Never buy HP. I say that as someone who has everything HP. Build quality is junk, they're just cheap. But the cheapness has drawbacks. No proper heat dissipation on laptops for example.
HP makes a wide range of laptops, and the Elitebook workstations are as well built (in the same factories) as half of the other high end laptops you'll find. They have their entry level junk laptops, but the larger Zbooks are put together reasonably well. Not terribly elegant, but they get the job done.
Postby amunta » November 21st, 2016, 1:44 pm
amunta
estardabill wrote:buy any laptop but don't buy laptop with graphic card.
what?
Postby MK19 » November 21st, 2016, 5:04 pm
MK19
step two
step two
That is true, but being poor (possibly also stingy) I was addressing the "cheap as possible" option.
In which case I say avoid anything HP that is in the low price range. I can only speak for UK prices but for £800-900 what you can buy from Asus or Lenovo is significantly better than what you can get from HP in terms of build quality and hardware.
Go to the Next Page
