ip_wirelessly
Please submit your designs to this forum.
Please keep discussion to the discussion forum: http://boards.core77.com/viewtopic.php?t=16201
1Hr Power Tool Design Challenge
Postby love2draw » Tue Jun 24, 2008 10:35 pm
love2draw
step one
step one
Hi All,
This is my [u][b]TRI-X[/b][/u] Power Tool Concept. Main features include:
- Combination of power drill + tube or wire cutter + grinder/polisher
- Rotating gear head allows multiple hand/tool positioning during operation
- Protective shield and hand-grip for maximum safety
- Rechargeable 12V battery docks on the back of the tool
Enjoy,
L2D
Screw Driver Hammer Plyers
Postby amexptl » Tue Jun 24, 2008 11:49 pm
amexptl
Hammer Head Plyers w/ ScrewDriver Tips - 1 Hour Thought
www.AmronExperimental.com
cousin of ManBearPig
Candy Jigsaw Summer Special!
Postby vauxhall1979 » Wed Jun 25, 2008 1:35 am
vauxhall1979
step one
step one
Done using solidworks in less than an hour.
1 hour power tools.
Postby johnnyS » Wed Jun 25, 2008 7:46 am
johnnyS
Our homes deserve better than powertools that look and feel plasticky!
After all, our homes are our prized possession.
Re: 1 hour power tools.
Postby rkuchinsky » Wed Jun 25, 2008 10:57 am
rkuchinsky
johnnyS wrote:Our homes deserve better than powertools that look and feel plasticky!
sorry, but i don't buy this was done in one hour...
Richard Kuchinsky / Directive Creator
http://www.rkuchinsky.com
The Directive Collective
HAMSTER POWER SAW
Postby theonette » Wed Jun 25, 2008 11:04 am
theonette
Well south Africa doesn't have power recently with its bad power cuts so I designed the ultimate power less power tool.
It runs only on carrots!
You can cover it with different designs but the initial internal ability is the seller
Although it only has a 1-2 year lifespan and no guarantee for pet owners
Postby bennybtl » Wed Jun 25, 2008 6:39 pm
bennybtl
this tool blows hard!
Fill up basketballs, paint your house, inflate tool toys, blow the cobwebs out of the crevices. Also works great for drying off after a swim! Towels are for sissies!
Cordless Driver
Postby Michael » Wed Jun 25, 2008 6:49 pm
Michael
step one
step one
My take on a Cordless Screwdriver/Drill - Self standing.
Couple quick sketches- 10 min.
photoshop- 45 min.
"There can be no progress without deviation" -Zappa
"In kindergarten they told me to color inside the lines. In design school the told me to think outside the box" -Schobel
Postby johnnyS » Wed Jun 25, 2008 9:16 pm
johnnyS
50 of us working at the same time will get it done in 1hr.
Postby ColinFinkle » Wed Jun 25, 2008 11:17 pm
ColinFinkle
Putting the 'power' in power tool. Literally.
Traditional gas generators are horribly inefficient and troublesome to operate. Give those powerpacks a trickle charge curtousy of the sun. Built in batteries and inverter allow traditional wall outlet tools to be used as well. It is based on traditional generators, and the branding of an unnamed company. (Any Guesses?)
Submission for 1Hour Challenge
Colin Finkle | Carleton University BID '07 | Industrial Designer with a Graphic Specialty
www.finkle.ca
human powered mechanical screwdriver
Postby PJ » Thu Jun 26, 2008 7:19 am
PJ
Fully charged whenever you are, this low cost IKEA® power tool will easily turn flat pack into functional furniture.
paul justin (C) 2008 - human powered mechanical screwdriver
On-Demand Power-tools
Postby quillasophink » Thu Jun 26, 2008 8:34 am
quillasophink
I remember reading an article featured here which mentioned something about power-tools being some of the most under utilised products purchased by most households with an average usage time of 20 minutes or so in a lifetime.
So my proposal is to have the local DIY/Home Fix store have a On-Demand Power-tools corner with mix-n-match possibilities!
A power-tool in essence consist of these 4 elements which I have narrowed down to:
1. A Handle of some sort
2. Drill/Tool Bit
3. Rotational Drive Shafting
4. Power Plant
Of which I have condensed into the 4 modular blocs of the tool:
A. Handle/Power Plant (H.P.)
Cylindrical high capacity capacitor units with nice kraton grips for those sweaty palms. Battery packs are to be charged and maintained by the DIY store (hopefully in a environmentally-friendly manner since the customer rents it for a couple of days and shouldn't be bothered with this task). This maintenance of the tools can be efficiently carried out and malfunctioning parts and can be easily identified and sent for servicing.
B. Central Hub
The core of any power-tool you require, it contains a multi-directional heavy duty servo rig that can be oriented to any of the 6 connector holes available featuring a dual twist locking system (i.e. twisting right then left and right again... you get the drift)
C. Tool/Drill Bit
Be it saw, drill, screwdriver or any form of tooling that involves rotational drive, it would be part of the arsenal.
Lastly there are the miscellaneous components like switches and hub-covers to patch up unused connector holes etc.
Errata: In the drill drawing, the cylinder in the centre was supposed to be an additional connector shaft in between the the two hubs to provide enough torque to get that hole you want in your wall.
P.S. Come to think of it it must have been apollo/soyuz memories from childhood that provided inspiration XD
School's boring. Which is why core77 rox.
1HDC Power Tool
Postby adenniston » Thu Jun 26, 2008 4:27 pm
adenniston
Hey Guys,
Here's my submission to the contest:
DuoSaw
This product is aimed at the DIYer who would love more tools but has neither the funds nor the space for them. It's modeled after the concept of a router/router table, where you can take the expensive components (the motor, the blade/bit, the electronics etc.) and utilize them in two different applications.
This design allows for the purchase of a circular saw that can be used as is, or can be mounted into a custom table saw table. The table would be significantly cheaper than an actual table saw as it merely serves as a base for the circular saw and does not contain any electronics or pricey components itself.
The circular saw would mount to a hinged arm underneath the table, which would still allow for the adjustable blade height present in current table saws. It could also utilize the tilting action of the circular saw for making mitered cuts.
Features:
- Low cost, allows for one time purchase of expensive components
- Combines two tools into one package for relatively low space requirements
- Gives DIYers access to tools normally only available to more serious woodworkers
- Form language would be gender neutral to appeal to both the women interested in being self sufficient and doing their own projects, without making those macho DIY men feel like they bought girly, substandard tools
Thanks!
Sustainable powertools
Postby VanDeBar » Thu Jun 26, 2008 9:33 pm
VanDeBar
step two
step two
Most powertools have something in common : they use a rotary motion. The idea is to reuse the same motor for different tasks by changing the front part of the powertool. Therefore, you save not only the motor, but a lot of material when buying a new powertool (or accessory in this case).
I didn't had time to draw the function of the rotating handle : by changing the shape of the object you can create other powertools such as this one :
http://www.professional-power-tool-guid ... Cutout.jpg
Go to the Next Page
