This is for all those that have jumped in the bath, only to jump out twice as quickly due to the bath being a lot hotter than you imagined! And then gone on to drain (aka. waste) the water and refil with a bit more cold, sitting on the side dipping your fingers in waiting for that perfect temperture. If you’ve had such problems, I introduce…
MAX… the rubber duck with a purpose!
MAX the duck uses a thermostat on his tummy, so when he’s bravely swimming about in your running bath the temperture is displayed on his backpack. Using his backpack the user can set their perfect temperture, when this is reached MAX will alert you with a few ‘quacks’. Allowing you to then maintain the desiered temperture, consequently avoiding the wasting of unneeded hot or cold water.
15 minutes - sketching
30 minutes - quick photoshop render
15 minutes - presentation
