Foray in computational design - Parachute Phone Case
Thanks for the response Ralph! I’m hoping to get the first one built at Shapeways soon, I’ll make it available for purchase if it’s up to snuff. You’re right about local impacts, I’m assuming the impacts are taking place against a flat surface. One thing the data did show me which is pretty obvious in hind sight is that the most likely point of failure is probably the corners but on the side of the screen. Not only is the glass fragile, most cases don’t have much protection there so not to impede on the use of the screen.
