Carbon rods are great for these types of applications.
You can also devise a platform allowing for different configurations using two boards - wood or plastic sandwich board - for the stiff sections that on the ends have a series of connections you can mount flexible rubber profiles onto.
For automotive frames we sometimes create rough prototypes from PVC tubing, these are quite flexible.
If you are more specific in terms of the desired properties I can give you better advice.
