Great start Hamed_Hamid,
Definitely a strong start to drawing fundamentals. I think you are doing a great job with line weight variation and understanding value. The drawing of the simple truck could use some attention to line weight variation, especially under the wheels so that it feels more grounded and not floating above the shadow.
Your drop shadows are a bit obtrusive. In some sketches they could be narrower with more falloff, and drop shadows in my view work better when they fall behind the object, with a 45 degree lighting.
In some sketches, like on some spheres, your key light is quite high, it works best at about 45 degrees.
The sketches with more contrast work better
Perfect your perspective drawing skills - in some cubes and cylinders it looks quite off.
I would like to see some sketches where you work with cold vs. warm tones for ground vs. sky reflections and shadows. The two color effect will create much more vibrance and pop to your sketches.
