Whoa. See, now you could really get some s*** done with that.
You could drop all that cash on a Mac Pro, too.
How often will you be working away from your apartment on a rendering? Or away from a computer lab at school? I know it’s cool to sit in a coffee shop, working on 3D renderings an have people walk by and ask what you’re up to, but you’ll work significantly faster on a workstation. Getting your work done faster results in you having more time to hit the bars with your friends, and less time resenting your laptop purchase.
You’ll get drunken texts from our buddies at 2AM, and you’ll just say “Damn this slow machine! I could be out partying!”
(Generated by PCPartPicker 2013-06-27 14:35 EDT-0400)
That is quite the beauty! But after researching the i7 4770k vs the i7 3840qm, it seems that the 4770 is only slightly faster. The only real advantage from what I can tell, is price and more disk space. Not saying that I wouldn’t love to save a grand! I guess it’s something i’ll have to think on.
That’s a hilarious way to put things into perspective, actually. Bravo sir.
What would be the advantage of running windows 7 on a Mac Pro vs building a desktop pc? Also are you alluding to the new mac pro or old mac pro?
Yeah, sorry. I noticed you had listed a few PC only programs up there.
Running Bootcamp works, but it’s not ideal. I work on a Bootcamp iMac and it does have issues and I’m not really doing anything difficult like rendering out of Solidworks or anything.
Another option. Continue to use your current laptop for light work and switch the to desktop for the heavy stuff. I would do that quite often during school. Id get all my renderings set up no my laptop in studio. Go home drop the files on my workstation. Hit render and cook dinner.
It was much more time efficient and it allowed me get a much faster machine that is far more easily upgraded in the future.
So sane, Sain. I sorta knew this was what I needed to do, but was too stubborn to actually want to do it. This is probably the route I will head down, as of now.
Just to clarify (I’m not sure if this is what you meant) more ram will NOT improve multi-tasking while you render.
Modern rendering software will eat up 100% of the available cores. That’s why your computer will suck at doing anything while you’re rendering even if you have 64 gigs of ram.
I won’t try to sell you on the desktop, there are reasons to buy a workstation class laptop, as long as you accept the fact it’ll be an unruly beast.
Truthfully you can probably spend much less than that and get a burly machine.
Go with the fastest CPU you can spec (which you’ve done), the best display you can get (if you plan on working on the laptop display itself), a 512 gig SSD, and 16 gigs of ram. 32 gigs is overkill - I do work on gigantic assemblies and I rarely push past 8 even when heavily multi tasking with big databases and renderings.
There’s a lot of factors to consider, though. Many rendering packages incorporate a “low priority” feature which will have the rendering job ease up a bit if the user is trying to do other things. Other packages let you set aside whole cores during rendering. (This is a tick in the “RAM doesn’t matter” checkbox.)
However if s/he gets into motion graphics or any poly modeling, there are plenty of functions which utilize RAM. Video rendering, dynamics simulation, retopologizing, all use RAM. (This is a tick in the “RAM does indeed matter” checkbox.)
But, really, RAM is so cheap, there’s nothing wrong with erring on the beefy side. 32GB is crazy but not as crazy as a $3600 laptop (I KID).
Lastly, a beastly enough computer will remain entirely usable while rendering. Having a properly cooled desktop instead of a groin-melting laptop will definitely help.
Everyone where I work does CAD and rendering on their macbook pros. Plus, the industrial design is great, so it’s good to show you personally value your field in your purchases. Even if I want windows, I just run boot camp (for Solidworks).
For the budget you have, I would get a maxed out MBP, honestly.
The thing I hate about my Macbook Pro is that it really sucks for running Windows.
The retina display is great but it is not optimized (in OSX or Windows) for most applications. As a result you usually end up with tiny windows, less than stellar GPU performance, or you go with the next best compromise which is running it in 1080P which is kind of a sin.
The other thing I’ve found on my MBP is Windows does not have the correct fan support under boot camp. I had to purchase a laptop cooler, and download a fan control app to set the fans to full blast while I’m gaming. Even then, the machine gets scalding hot after a few hours of gaming. I’ve already had several full system lockups due to heat, so I can’t say it makes me want to recommend it as a machine for rendering on. Nothing like waking up the next morning to find your CPU hung overnight and nothing got done. My machine was hitting 105° C - which if you’ve ever looked at how processors work, they start shutting down at 100C to protect themselves from damage (yes C, not F). That’s absolutely insane, and the heat travels VERY quickly through to the top of the keyboard.
Don’t get me wrong, I love the machine in many other regards - but for the purposes of pumping cad it’s kind of like buying a BMW X6 because it’s a good “off roader” sometimes it’s worth it to get the Jeep and not care what people think.
Personally I like HP’s current lineup of Elitebook workstations (I also run a 8560W) - they have some of the Macbook flare (keyboard, metal chassis) with the PC things that make me happy (dedicated VGA port, ethernet jack, docking station).
The macbook isn’t a bad choice, but it’s not as perfect of a choice as I once thought it would be after owning one for a few months.
If you are looking to do it all on one machine and move it from place to place then a strong laptop is the solution.
As mentioned before, cooling is the Achilles heel of working on heavy renderings, I know that feeling of waking up in the morning to find a shut down machine due to overheating instead of a in depth rendering.
I now have a big, angular, matte black, heavy, Asus Gaming laptop. The laptop has never overheated even during multiple day rendering sessions with all threads maxed, it has two big fairly unattractive fans at the rear that carry all the heat away, which on the very occasional time it sits on my thighs means that there is very little heat felt.
I am not looking for any nods of approval when I flip up the top of my laptop in public. Actually the looks are of shock,
Sager (Sagernotebook.com) also makes very solid machines AND they have some seriously high end desktop replacements:
This guy can get equipped with a GTX 770M (Consider what apps you run and if you need the Quadro card for full support) - as well as the 6 core extreme edition CPU and a SSD + 32 gigs of ram for under $3500 and that’s a beast if you’re just looking for computing power.
With that said, it’s 12 freaking pounds without the power brick (which is probably 3-4lbs for a machine that big). Expect to get either really strong shoulders or a hernia if you want something that is actually transportable for long distances. You certainly wouldn’t want to make an hour long commute with that thing.
I would recommend getting way more than 8 gigs of ram. At the cost, you might as well go with 32. You will be thankful for it as soon as you toss some displacement in the scene. Seeing “unloading geometry” will always ruin your day.
If you are really serious about going the 3D route, I would really stay away from the laptop. We have the top end dell and it will throttle itself after a bit due to the heat issues. Also, dont expect more than 2 hours of light duty CAD work on a machine with top end specs. I think that the desktop example given is a great one, and leaves you with 1k to get yourself a decent laptop to stay mobile. You can model/prep your scene on almost any decent laptop. Almost all the top rendering programs will allow you to distribute the rendering to the desktop to take advantage of the power it can supply. Also, you can upgrade the CPU on that machine if you ever want to later. And trust me, you will.
I wish I had more ram/processors in mine most days:
Hey guys! Thanks so much for all the advice and guidance throughout this thread.
After careful consideration I have decided to stay away from a Laptop and am now in the process of detailing a desktop to suit my needs. While it would be great to have a laptop to work where ever I please, I do not feel that it is absolutely necessary and will probably be happier with a more reliable and upgradable machine. Hatts, in an earlier post directed to me to http://pcpartpicker.com where I could piece together my machine, so I think that is where I shall start.
If anyone has any other suggestions for powerful workstations, by all means, lead me to them.
I am planning on using the i7-4770k processor with either a quadro 4000 or geforce 780 card and 32 Gb’s of ram. I am lacking a motherboard, cpu cooler and an appropriate power supply, so I need to do some research on appropriate parts for my machine.
CyberDemon - that’s crazy hot. I have also had several-hour gaming sessions with my home MBP and the fans are fine (full blast). Never seen temps, but pretty sure they are not that high.
Also, Windows 8.1 has HD resolution support.
@NURB - the Cobbler’s kid has $3500 for shoes. He can afford some nice ones. =)
Unless someone is a professional renderer and not a designer, I don’t know why they wouldn’t want a laptop these days. To each his own!
