Here is a suggestion for the Engineering section – if you are able, rework the drawings to eliminate some digits after the decimal place on some of the dimension. I am sure you are ware that if you have a critical dimension (like a shaft for a press fit) that really does need to be 5.002 +/- 0.001 that is fine, but to call out the width of the gear box to 19.000 would be wasteful if it can be 19.0 +/- 0.1
One other part about which I am uncertain is the molded housing.
If those two features are ribs, they will need some additional ribs or other features to connect with them or the mold will never fill.
Overall, my opinion is that you should have no problem getting interviews.
