gear used on cassete deck door to open slowly?
Can you post specifics of the project for suggestions on getting a similar effect?
It’s a spring-damper system (the same system used in door closers, car suspensions, etc.) dominated by damping. You can get dampers in a variety of forms, including the rotary damper above and linear dampers. They come in various strengths as well.
