Solidworks To Rhino
The confusion is totally reasonable; “solid modeling” is sort of a disorienting term.
“Solid modeling” is, in a way, a fictional concept; it’s just a workflow method where the software continuously checks that your NURBS object is a watertight volume. If the object becomes non-manifold it either scolds you or it switches to traditional surface modeling. A watertight NURBS cube is identical to a “solid” cube.
