Retainer / Part Time ID
Also, keep in mind, your rate will also likely determine how much you are working. You can have a super high rate and freelance every so often on the side, or a lower rate and work constantly. Also depends on the scope of the project. Smaller, shorter projects can bill at a higher rate, but if you are working on long or extended projects a high rate wouldn’t really make sense. Esp. more so in a retainer situation.
