Plywood supplier in San Diego
Postby engelhjs » February 3rd, 2012, 2:13 pm
engelhjs
I'm working with a charity connected with the Zoo and Safari Park to design and construct some small, bent-ply animals. Could anyone in the SD area recommend a good supplier for small quantities of quality plywood and veneers? Thanks.
Jeff Engelhardt
Industrial Designer - Footwear & Softgoods
Giro Sport Design
Santa Cruz, CA
http://www.jeff-engelhardt.com
Re: Plywood supplier in San Diego
Postby DCypher » February 3rd, 2012, 5:59 pm
DCypher
Frost hardwoods off Miramar rd has some 3 ply bendable sheet in 1/8th inch and they also carry hardwood veneers. Don't think they have the epoxy resin but if it's not super rigid you may be able to use just wood glue. other than that no-one I have found in San Diego carries anything in thinner ply. maybe call around. I had to soak the 1/8" plys in water because the radius I was using was too small for the wood and it would otherwise break. I then put them in the form to dry out, then I glued them together. very laborious process but it worked out okay.
If someone uses the cliche "form follows function" one more time I'm going to scream!
Postby engelhjs » February 6th, 2012, 2:40 pm
engelhjs
Thanks for the tip. I'll check out Frost.
Jeff Engelhardt
Giro Sport Design
Santa Cruz, CA
Postby scrotum » February 6th, 2012, 6:09 pm
scrotum
The first thing that came to mind when I read the thread was the Eames Elephant, although these days they are made of plastic.
Postby engelhjs » February 6th, 2012, 6:13 pm
engelhjs
Definitely where my head was at, too.
Jeff Engelhardt
Giro Sport Design
Santa Cruz, CA
