This is so duh, I’m sort of bewildered that it’s not a standard thing.
If you remove the remote from its spot on the coffee table, the TV, stereo, and whatever device the remote is linked to all turn on, and the lights dim automatically. If you replace it, they all shut off and the lights come back on.
Could use RFID or something similar to make sure that it’s actually a remote and not a stray tortilla chip. Could use a battery instead of cables & keep everything wireless. The gesture is the same, though: Pick up the remote to watch something, put it down to stop.
I wanted to do something with the ritual of leaving your house. My idea was to have a relationship between the lock of your front door and the lights inside your house. When leaving your house (and locking the door) you may have thoughts like “did I close the gas?” or “did I turn off all my lights?”. With this solution it will be impossible to lock your front door when there’s still light(s) turned on in your house. You will have to turn off all the lights to be able to lock the door. And if there’s someone else in your place, there’s no need to lock it in the first place Also, it will only work when trying to lock from the outside, not the inside.
In some cases this solution might be undesirable, e.g. keeping lights on for safety purposes, or when you’re simply in a hurry. But, it will definately make you more conscious of your energy usage. And, you will be reassured that indeed all lights are off when you can lock your front door!
One day I forgot to turn off the gas, and it kept on burning all night long… I guess the solution should be pretty logical : nothing on, no heating : more security, more energy efficiency.
The second concept is more focused on intuitiveness : you should know how how strong is the heat without looking at the little numbers on the vitroceramic, and I think the classic interfaces are not really user-friendly (slow in changing the heat, not very responsive…).
Tipulator…
Used in the hospitality industry and set to a national standard
The Tipulator calculates the percentage of tip the customer will leave based on a 5 star rating.
For example:
1 star = no tip
2 star = 5%
3 star = 10%
4 star = 15%
5 star = 20%
and 2.5% for every half star
The Tipulator holds the receipt like a standard bill book and then based on the star rating given the Tipulator calculates the tip. It then prints a total including the tip with a star rating on the receipt.
This can then stream to an online review site giving the restaurant a true up to date review.
This design is partly touch sensitive however, could be entirely touch screen with a thermo receipt printer incorporated reducing paper consumption.
This is a concept to avoid those occasionally awkward moments at the end of a meal out. Trying to flag down an already stressed or nonchalant member of staff to get your bill.
1. When the customer(s) sit down a candle is lit, a nice way to begin I think we’d all agree.
2. The customer(s) have their meal as normal.
3. When the customer(s) want their bill they blow out the candle symbolising the end of the meal, alerting the staff to this fact in a poetic gesture.
This could be as sophisticated as you like. The staff could keep an eye out for the tell tale smoke which appears when a candle is extinguished, or at the other end of the spectrum, a thermally sensitive component could be installed in the candle holder which communicates wirelessly with the restaurants tills, automatically printing the cheque to be delivered to the satisfied punters on a silver platter.
Here’s what I came up with in 5-10 minutes for the 1HDC. I will try using the 50 left for other Ideas. It is self-explanatory, you can’t leave your room without turning the lights off.
The evident physical obstruction makes the user aware (I definitely hope so) and invites him to think in terms of causes and consequences.
I was intially thinking to install a floor tazer, but hey, the whole goal is to save electricity no?
The ‘RunAway Mouse’ is activated by the cat’s collar. As the cat walks past the mouse the mouse begins to run. This action entices the cat and causes it to chase the mouse.
(First, this product DOES NOT make the drink for you. It is not a vending machine. )
The Siren is an ordering device that uses rich, interactive gestural controls to allow the customer to custom craft his or her drink. The controls are designed to simulate the real action used by Baristas.
For example, to add espresso shots, toggle a horizontal lever which resembles the espresso portafilter. Three clear “ice” button toggles determine the amount of ice, and a cylinder resembling an inverted whipped cream aerosol can is pushed to add whip. A large hand crank wheel is used to add “foam”
Once the drink is specified, a printer located below the cup prints a QR code on the bottom. This code is used by the baristas to know what you ordered. You can also scan it later with a cell phone cam to tweet what you just drank.
The Siren also features a “siren” button which can be used to complete a partially configured drink based on your order history, tracked via your starbux card. When this aggregated drink data is combined with advanced barista algorithms it can be used as the “siren’s intuition” to generate a new drink you might like, on the spot. Putting a generative design tool into the hands of customers.
(also, this is supposed to be a little silly, but in a fun way. The QR code actually works, try it)
ALL 3d idea writer
A designers best friend. Using Key descriptive words the ALL 3D idea writer presses and shapes your thought.
The more poetic the written content the more cohesive the 3 dimensional output.
WORD.
I wanted to bring more play and interaction into working with a computer.
Didn’t really play around with the form so much as the idea.
Roll to scroll.
Bounce to zoom the screen. Bounce on walls, desk, floor.
Hold button(s) and tap to zoom out.
Ball glows green when battery is full and red when low.
Im going into my junior year in the I.I.D. program at Syracuse University (second year). Figured I’d give it a shot. Feedback and tips are appreciated
