Typically it’s a toaster oven because you can also use it as a small oven for broiling and such (goes up to 350-450C), much higher than a toaster. It’s a toaster because you can also use it on low power to only toast toast.
NOT the same as a normal full size oven.
I don’t like them because they are usually ugly and take up so much counter space.
