Sorry, mine was done in an hour but it was a prior project. Good luck!
Hi core 77ers,
A colleague forwarded me this challenge and I’d love to propose using pleating folds as a system for deployable shelters. I used to be a “paper engineer”, designing pop up books and cards, now I work with scientists folding things on the micro scale. Collapsible structures may ship flat and expand upon arrival… the models are made from 100# text weight paper but can be made life size (or cat size) with polymers/ plastics and then covered.
A quick pass at this ONE HOUR DESIGN CHALLENGE. This was 40 minutes, super obvious, but maybe so obvious it could work. Essentially a giant umbrella with the center shaft doubling as a fireplace. It might need to be tied down like a tent for stability in winds. Sideskirts can be fastened to the lip of the roof. It could ship easily in planes, trucks or trains.
sketch got a little busy, but hopefully you get the idea. It’s a tent that can be dropped from a helicopter (or deployed from land) that is kept aloft by balloons that have computer controlled rotors to keep it in place, and can be easily moved accordingly as needed.
The structure of a tent or shelter is normally the heaviest and most material consuming part of the structure, and this solution removes the need for such support to provide cheap, quick, easy to deploy basic shelter from sun, wind, and the elements.
The tent and balloons also may have graphic markings to help identify different triage wards, groups, families or sections which can be easily seen from air and land to help ground/air relief workers and those in need of help find the correct tent.
Inspired by the Dymaxion housing concept by Buckminster Fuller.
1Hr.
Hi
This is my take on the shelter-design:
Based and collaborated on this amazing idea: seedbomb by Jin-wook Hwang at Coroflot.com by Jin-wook Hwang.
The Basic Idea is that the inflatable shelter (and other necessities: food, stove, medicine) are stored inside mock-ups of real bombs. That way these rescue-packages can fit inside a military bomber. So these planes might help people instead of killing them.
I do hope the sketch speaks for itself…albeit its quick n dirty…but that’s the challenge I guess
Grtz
T
PS/ As for a name I’d suggest: “Bomb the Poor Basterds”
I’ve been working with a large blow molding factory in China for about 5 years and I’m amazed at how big they can blow mold hollow panels. They make the light weight blow molded folding tables for stores like Target.
- The panels are light weight and strong, which makes it a great material / process for modular construction.
- The panels ship neatly in containers (perfect cube) and can be hand carried to remote sites (if the roads are trashed after a disaster).
- The ball-and-socket construction makes for easy assembly.
- The hollow panels can be filled with water or sand to help lower the center of gravity.
My idea stems from roll-out tarpaulin panels (mostly used for event signages) but for the shelter design, a wider and hardier pole (roll pipe) will be used, and the edges of the poles will have designated locks to: 1) insert at the base, 2) connect wall-poles to roof-poles and 3) a main connector to close the door.
Since this shelter is not for long-term, the base material may be made of particleboard which can be composted after use, and the bed materials are also organic.
The walls of the shelter is a continuous tarp rolled out from the 4 wall poles, this feature makes shipping/transporting very easy; and its varying tarp colors will identify which one is the roof, the wall, and the door.
Hi! Yes my entry was done in an hour AND it was original for this competition. I’ve drawn pallet houses before but never one so small and never one using earthbags.
-Michael
Credit is given to the American Indians TEEPEE design for it’s durability, portability, and responsible use of natural resources. In this concept the material (tarp, canvas, gore tex…) would be provided to skin the frame. The units cold be set up alone or combined to form multi-room living spaces.
Hey Guys heres my entry
took me just under 50min on my lunch break so might add a couple of extra sketches later if I can find the time.
Explanation:
Aid Box: Stackable and easily transportable, designed to get the maximum amount of aid effectively to the places which need it. Rather than just supply a shelter, Aid box gives the people in need the basic essentials to help bump start rebuilding their lives.
Box features:-
- Stackable, for effective transportation
- Measures so will fit into a container or aircraft with the minimum amount of negative space.
- All parts of the box have additional features and purposes.
- Can be sterilized and cleaned after use for re-use by aid agencies in other areas.
Tent:-
- Fold from inside the box staying attached.
- Straps of the box are used to tension the poles creating the tunnel shape
- Colour-coded 4 step, simple construction
- Sleeps 6-8 people.
- Tough, waterproof construction with built in mosquito net.
Box:-
- When emptied the the specially designed aid box becomes a cool box for keeping food dry and cool.
- Internal box hold basic equipment for cooking, eating and drinking
- Internal box then acts as a water storage with additional tap attachment and filter
- Strong sturdy construction, which can sustain the rigures of the tough conditions of use.
Hello
This is my first time entering one of these competitions. Lovely work so far. Really impressed by the creativity in the solutions.
This is a simple design for a unit inside a lightweight metal container. It consists mostly of rods and fabric. It really is simple to construct but should be sturdy too. It makes use of collapsable metal foil for chimneys and rainwater storage. I did it in about 30 minutes so please excuse the rough drawings. February 4th - I’ve edited this drawing to remove my name from it.
I would challenge everyone to try to beat this (or donate to the cause):
This design utilizes an existing component, which is inexpensive and easy to manufacture. It inherently provides a rugged shelter in an assortment of harsh weather conditions. Reusability and recyclability were also factors in the design.
The idea for this shelter is that it basically is a small house, not necessarily a temporary shelter. It consists of a wooden floor element on poles that can be cut to length on location to meet various ground surfaces, and 6 styrofoam shells with a fire retardant coating. This is lightweight, probably pretty safe, easy to assemble, good thermal insulation, and it would probably stay intact in a mudslide too.
The idea came in a few minutes and I managed to just stay within the hour in raw Solidworks minutes.
Using the net of a cube it easy to make or build a shelter following the simple steps of the cube, using light and resistant materials. Its easy to store cause you can fold it back in and store it.
Emergency Shelter
The pre-cut cardboard is assembled to create the house shaped structural enclosure.
The section profile is created with are small cardboard pieces, overlapping each other’s joint line/cutouts to create the overall structure.
The internal side of the structure will be useful to store small items, to tie a rope for clothes, to hang the lights…etc.
The canvas/tarpaulin sheet will be laid over the structure.
The canvas will have the double weave & single weave combination to allow air & light to pass through them.
The material options like plastic or cardboard & tarpaulin or canvas will be selected depending upon the weather conditions in the affected region.
Hi
Basically trying to cover the basic needs in buildings: Sleep, eat and hygene. In a way that is cheap and fast.
Doing this by making simple shelters of plywood, tarp and poles. This makes it lightweight, cheap, easy and aftershock “safe”.
Empty containers can be re-used as ad-hock buildings for sick-bays, latrines and showers.
To ‘remember when’:
Check out this video: - YouTube
I love how it unfolds
Might be inspiring for your idea
grtz
Quick and dirty idea. Two similarly shaped folded metal pieces nest one on top of the other. The top piece can rotate to open the space up and create a door or to close off the shelter completely. The roof becomes concave due to the folding process and has a hole in the center fitted with a water collection pitcher and filter. I imagine these being shipped flat on a truck and folded on site with a simple plywood/lumber mold and using human weight.
