Product Renders
Postby msHutch » April 11th, 2018, 9:02 am
msHutch
I had a question the other day and thought I could maybe find some answers here. I have been working on improving my rendering abilities (mainly using keyshot). And I noticed a common thing people who are very good at rendering have been doing a lot recently. It looks like a lot of people are adding noise in post production to their otherwise photorealistic renders. I am just curious as to why this is because I have been trying to improve my rendering and I am trying to avoid noise as much as possible.
Is it just because it makes a cool looking image or what?
-Michael Hutchings
LinkedIn
Re: Product Renders
Postby MK19 » April 11th, 2018, 9:23 am
MK19
Please show some examples of what you mean.
Re: Product Renders
Postby msHutch » April 11th, 2018, 9:30 am
msHutch
Here are two examples. It just seems like it is a film filter on top.
Image Source
-Michael Hutchings
LinkedIn
Re: Product Renders
Postby ralphzoontjens » April 11th, 2018, 10:15 am
ralphzoontjens
Using that amount of noise in any professional design studio is unacceptable, unless the effect is very strikingly done.
It gives an illustrative effect which is nice for internal presentations to other designers or artists, but clients actually want to see popping renders that communicate well, not so much artistic ones.
In some occasions, say vehicle renders, you can use a film grain.
Sometimes a computer render looks very CG-like because in reality the brain receives a higher variation in lighting details.
For example, renders often either look cold or warm while in reality there is always a balance.
What you can do to increase the perceived information is add a slight noise. What I do is 1% noise and then increase the highlight levels overall (from 255 to 242) so the background remains a pure white.
http://www.designsoul.nl
Re: Product Renders
Postby msHutch » April 11th, 2018, 10:23 am
msHutch
I appreciate the reply and the insight!
I figured it would be unacceptable for clients to see, I just wanted to make sure I wasn't missing a trend in rendering now a days or something like that.
I will definitely try the adding 1% noise and increasing the highlight levels in my future renders.
-Michael Hutchings
LinkedIn
Re: Product Renders
Postby Cyberdemon » April 11th, 2018, 11:09 am
Cyberdemon
Some rendering engines are inherently noisy without a long amount of time to process or high enough raytracing settings. Some of it could be post processing for effect, a little noise can add some film grain that makes a perfect render look more natural.
Re: Product Renders
Postby yo » April 11th, 2018, 11:29 am
Looks more like a render that wasn't done yet to me. If you render directly in Fusion 360, and set it to render on screen it will be grainy like this until the render is complete.
Re: Product Renders
Postby Lowe9 » April 11th, 2018, 12:31 pm
Lowe9
step one
step one
Here's an example of render that look like the noise was intentionally added. Or it could have been only been added to the background to better match the textured plastic? Regardless, I've seen this trend more and more over the past couple years, especially in portfolios of newer designers.
https://www.behance.net/gallery/5482711 ... OLLER-2016
Re: Product Renders
Postby msHutch » April 11th, 2018, 12:44 pm
msHutch
yo wrote:Looks more like a render that wasn't done yet to me. If you render directly in Fusion 360, and set it to render on screen it will be grainy like this until the render is complete.
Cyberdemon wrote:Some rendering engines are inherently noisy without a long amount of time to process or high enough raytracing settings. Some of it could be post processing for effect, a little noise can add some film grain that makes a perfect render look more natural.
I realize that renders a lot of time are noisy if the render isn't given enough time to process. I was bringing this up more in the context that Lowe was saying
Lowe9 wrote:Here's an example of render that look like the noise was intentionally added. Or it could have been only been added to the background to better match the textured plastic? Regardless, I've seen this trend more and more over the past couple years, especially in portfolios of newer designers.
I have just noticed this trend happening a lot recently and was wondering if there was a reason for it.
-Michael Hutchings
LinkedIn
Re: Product Renders
Postby MK19 » April 11th, 2018, 1:06 pm
MK19
In the lamp example it looks like it is intentionally done in post processing (photoshop) to take off the too-polished look renders can have.
As has been mentioned above it is not something that would be sent to or shown to clients.
In this field you have designing for the real world (i.e. clients and business) and designing for designers. They are two very different things.
Re: Product Renders
Postby Cyberdemon » April 11th, 2018, 1:09 pm
Cyberdemon
msHutch wrote:I have just noticed this trend happening a lot recently and was wondering if there was a reason for it.
The reason is many renders look too perfect, so adding noise is an easy way of introducing some more realism. Same as adding bokeh using a camera blur, etc.
Re: Product Renders
Postby msHutch » April 11th, 2018, 1:28 pm
msHutch
I just did a quick render of a chair I designed a while ago to see the difference between adding noise vs. no noise. I can totally see how it gets rid of the "too polished" look of the render and sort of helps to hide the crimes of some small mistakes.
With noise (probably too much)
Without noise
-Michael Hutchings
LinkedIn
Re: Product Renders
Postby engelhjs » April 11th, 2018, 1:50 pm
engelhjs
The "too perfect" effect often comes from a combination of a few things that include unrealistic lighting or shadows, shaders that lack the depth and complexity of real-world materials, and surfaces that lack fine detail. Noise can be used to alleviate some of these because it has the ability to simultaneously obscure poorly rendered details (e.g. bad fillets or edges) and add missing detail (e.g. material texture.) It can also give a feeling of reality as we tend to associate noise with the film grain present in actual photography.
When used solely as an attempt to elevate what would otherwise be a mediocre rendering, though, it becomes a crutch just like using an Instagram filter to elevate a mediocre photo. Really dig into your materials, lighting, and geometry, and you'll eventually find that a noisy rendering will generally look inferior to something more polished.
Jeff Engelhardt
Giro Sport Design
Santa Cruz, CA
Re: Product Renders
Postby louis leblanc » April 11th, 2018, 2:12 pm
louis leblanc
Lots of CG artists have been doing this for a while. I see two main reasons for it.
First is a purely stylistic choice. Just like some inspirational sketches are highly gestural or try to create a mood, grudging up a rendring can change the perception of it. Hey even photographers apply these kinds of filters to photos. It can also help with work in progress renders from looking like finished products and leaves them a bit more open for interpretation. I'm on the fence about it, it feels more like a trend than an actually useful trick. There are other ways of making renders not look like finished products like blending in line work from the CAD model.
The second reason is photorealism. If you want to look photo real, you'll need to simulate the camera at a certain point. This is where masters tastefully apply very gentle filtering to simulate grain, lens blur, lens flare, chromatic aberation, depth of field,... In this case you'll see much more refrain in the use. Noise can also be really great when making composites with real images. First to match the grain in the original image but applying treatment to the overall composite often helps tie the different parts together.
Re: Product Renders
Postby MK19 » April 11th, 2018, 2:13 pm
MK19
Dropping mats on and rendering something out then adding noise is much faster than properly setting up scenes, lighting, mats, etc. though. For something quick and dirty it is probably more appropriate to do the first.
Go to the Next Page
