is there anyway I can easily (and at home) add permanent designs, colours or graphics to plates and other table ware???
are there paints or dyes that can be used?
I want to revamp some boring plates… anyone/???
I saw inkjet prints applied somehow to dinnerware plates on an old episode of trading spaces. I don’t recall the method… perhaps the iron-on papers you can buy?
How is it that those those mall-stands apply photos to mugs?
I think the mugs are done by a dye-sublimation process. I think there is heat involved.
if they are just “artsy” and do not have to hard edge detail Pebeo makes a number of products thatcan be used. i guess you could whip up a type of mini silkscreen if you want better resolution. I’m not sure they do coffee mugs buts I’m sure it’s a silkscreen or pad printing process.
(not talking about those put your pic on a mug type of process)
well, i was thinking of really simple patterns, stripes, etc- jsut on plain white plates. not full photos or anything…
how can i whip up a “mini silkscreen”…?
The artsy-crafty stuff…
Jo Sonja’s glass and tile painting medium - I’ve never used it but it seems that you can mix the medium with any color to create the paint that will bond to a surface…and then you bake it at 330F?
http://www.dickblick.com/zz007/12b/products.asp?param=0&ig_id=5647
Pebeo Porcelain 150 – a water-based, thermo-hardening paints…
http://www.dickblick.com/zz029/08a/products.asp?ig_id=6785
Pebeo Porcelain 150 Paint Markers…
Yes…How can one whip a mini silkscreen?
