Keyshot 4 - Label Application
In KeyShot 5, for packaging, create the label full size and save at 300 DPI. When you apply the label to the material use the DPI check box in the label panel and specify the DPI . It comes in at full size. Make sure you use the same units for everything. You will still have to fuss with alignment.
