SolidWorks Setup
Postby umlautthoni » February 19th, 2013, 8:42 pm
umlautthoni
I'm due for a new laptop at work. Unfortunately, it will be another Windows based machine. I'm a Mac user; always have been, always will be. I need to supply my IT dept with the specs for a machine. I need it to drive a 27-in monitor as well as a 21-in Cintiq. My last laptop would only allow for both to external monitor and Cintiq to run simulataneously. Does this make sense?
If anyone can reccommend a best practice, I would be hugely indebted to you as I have never been a technical wiz at this sor of thing.
I use Solidworks, Photoshop, InDesign, Illustrator and Keyshot applications for design work.
Re: SolidWorks Setup
Postby d8m » February 20th, 2013, 2:56 am
d8m
As far as driving Solidworks goes if the moneys not a problem the simplest thing to do is just go for a dell precision laptop. Probably skip the base model and go for the mid range.
I have had 2 of these laptop in the past myself(one lower spec model purchased by myself during uni and another purchased by my employer for me)
The one from the employer used to run 2 24" monitors with Solidworks and Altium running with no problems at all.
If Dell are not an option find yourself the American version of a site like this:
http://www.pcspecialist.co.uk/
and build one up to your own spec.
Hope this helps.
©2015 Core77, Inc. All rights reserved
about | contact us | advertise | mailing list
cron
